Allow Sam to do mapping for all modules so it can follow you around the area.
Hi there, thanks for your suggestion—we appreciate you taking the time to share it.
At the moment, this feature isn’t something we’re planning to support. Thank you for your understanding.
You can map with the SAM on. But nok with follow you. You just have to take into account that the mower and the snow thrower are larger so it can be difficult in the corners. You just can’t adjust the tasks until you put the right module on.
You definitely can map with any module but it is strongly advised to use the module you intend to use that area for when creating the area for the reason you said. To account for the size of the module when you are creating the map.
