Will you please recommend some silicone grease brands and distributors for track maintenance use? thanks
Yarbo’s own is preferred. There is a document in their Support KB outlining the properties of the grease they require: Yarbo’s track lubrication information
On FB there has been discussion of people using other silicone-based greases:
- Super Lube (available at Home Depot) Silicone Dielectric Grease (and other similar ones)
- EDSRDUS (or similar spelling) High Vacuum Grease
- OAIEGSD Silicone Paste
Whatever you go with, make sure it meets the requirements in Yarbo’s support KB document.
Thank you for your question! We also offer track grease on our official website — you can check it out here: Yarbo Track Grease (200ml)
Thanks for the info
How is the grease applied to the 2024 tracks? Mower only if that matters. It said to contact technical support, but surely it can be posted in the forum? Thanks.
I’ve been using NAPA Sil-Glyde silicone grease on the tracks, applying about 3 screwdriver-size dallops on each side once per week. It seems to work well.
It would be super nice if Yarbo would sell or recommend a plant based grease. We are trying to not buy any more dinosaur juice.
Tim
Hmmm pure silicone is inorganic, and not fossil based. But silicone greases often contain fossil products. Can we get a data sheet on the material, or is it possible to get someone in Yarbo engineering to confirm that the grease is truly “green”?
Tim
but how long does it take its been a month since my last order of items and no tracking or any info…not sure if all your products are on backordered now
We’re very sorry for the delay. We understand how frustrating this can be. We’ve contacted our logistics team to prioritize your order, and you should receive your tracking number very soon. Thank you for your patience, and we truly appreciate your understanding.
I searched out a lithuim based, as Yarbo’s price is a bit much. I came accross Molycote 33 low temperature lubricant.
It seems work great and only requires about a toothbrush full on each track about every 3-5 hoursw of use. Work’s well at -28C or -28F.
I found it at an aircraft parts supply locally, they are in both Canada and USA, recieved delivery witin 48 hours !
Its not cheap, available in other sizes.
Sad Yarbo didnt include a small amount of track grease with the new Snow blower with the cleated track option.
I am a little surprised they don’t include some with the core as well. Maybe that’s a good suggestion @Yarbo-Forum Glad that’s working well for you. I’ve also found this to be fairly inexpensive and very easy to apply with a grease gun and a hose attachment to it.
Super Lube Silicone Lubricating Grease w/Syncolon - Waterproof, All Purpose, Food-Grade Grease - Rust Protection - Automotive & Industrial Use - Translucent White - Cartridge - 14.1 oz (92150)
Molykote 33 Update, put about a toothbrush full on each track every 2nd time I did the driveway.
Tracks were still able to run full speed at -28 c or -28 F even when cornering or rotate inplace the tracks did not bind whatsoever. They show little signs of were on the inside and I could sure use some replacement cleats/screws for the tracks.
Really happy with Yarbo’s 1st winter, atleast 42 days consecutive use and several other 1x snow’s all via the Yarbo hand controller.
