Snow throwing when yarbo turning
development proposal for yarbo snow throwing, if the throwing direction is set to one direction then it would be good for the auger to stop when turning, otherwise it throws snow, for example, onto the wall of a house or onto cars
This has been asked for by many people. Hopefully it’ll be implemented in a future release.
They are actively working on this.
Hi there, thanks for sharing your feedback! You’re absolutely right—this is an aspect that still needs improvement, and it’s something we’re actively working on. We really appreciate your suggestion and the real-world use case you mentioned. Thanks again for taking the time to share your thoughts.
I and the customer also have problems with the snow throwing direction, mine throws in the direction of the red arrows, for example, even though the throwing direction is set to one edge. The customer throws into the windows and the garage wall even though the throwing direction is set to the other.
Is it consistently doing this or just when turning and maneuvering?
Are you on the latest firmware? 3.12.0 is the latest. If so, would you mind sharing the plan preview?
Hi there, did this issue occur after installing the latest firmware version 3.12.0? In this update, we optimized the snow-throwing behavior of the snowblower, so what you described should not normally happen. If you’re still observing this behavior after the update, please feel free to submit a support ticket so we can investigate the issue further.
