Snowblower shows yard map
Switched from mower to snowblower but the app still shows yard map.
@Jerad_C welcome to the forums.
That is the current design. Yarbo recently added the ability to “add labels” to the work areas for different modules.
Hopefully at some point we’ll be able to filter/hide work areas based those labels.
But right now, it’s all we have.
You can build work areas on top of work areas to get the job done.
You can also save your map and delete and restore later.
The only caveat with save/restore of the maps is that it does not save any settings.
Thanks @steve
You can filter based on those labels today. Enter your yard and edit map.
What kind of non-standard filter icon is that. I would have never found it :slight_smile:
“Map Layers”.
That makes more sense.
