Is anyone else having issues with Yarbo’s NETRTK service today?
Yesterday I lost GPS for an amount of time in one area of my yard that normally has no issues.
It happened again today in the most wide open area of my yard that there is, and under clear blue skies. I manually drove it back to the charging base, but now 12 hours later it STILL has no GPS signal.
I’m on cellular connection, which seems to be working fine, and NETRTK which does not seem to be working at all (Status=1)
Did you reboot the core or try disconnecting the battery for 5 mins? Are you strictly using cellular or do you have the DC with HaLow in place too? If so, unplug your DC for 5 mins. It is also possible you may have hit your cellular data cap. What is your current usage at?
Hi there, could you please try Bryan’s suggestion first and check whether the issue still persists?
If that does not help resolve the issue, please submit a support ticket with a detailed description of the problem. Our support team will need to review the device logs to further investigate and identify the root cause.
