No GPS signal, middle of the yard
Yarbo has no GPS signal in the wide open. I can see that it finds 24 satellites, but isn’t connecting to any of them. No tree interference or any other blockage. Started happening after latest firmware update.
Thanks!
Mind sharing some screenshots of your diagnostics? RTK, status, Data Center, and Halow Sections. Also tap “Details” under RTK and connect to your DC and snap a screenshot of your DC scatterplot.
Could you please provide some more information so we can help investigate this issue further?
In the meantime, you can also submit a support ticket so our team can look into it along the way.
Thank you!
I attempted to restart the RTK and Yarbo, which is worked in the past, but no luck.
Later in the afternoon when I attempted to open the Yarbo app, it informed me that there was an app update. After I did the update it seems like the gps signal is back now. Not sure why that would have helped the GPS, but must have done something.
I will post the stats if it happens again.
Also, I was looking through all the options and see that the NetRTK is now an option. Is that a better option than the physical one that I have installed? More reliable? Or would cloud cover or snow storm make the NET version less reliable?
If your DC is properly mounted with a clear view of the sky, no obstructions, and working properly, there is no need to switch. It will also be a subscription service after 90 days unless you were a Kickstarter backer.
Ok thanks for the explanation! Physical RTK it is
Do you know the cost after 90 days?
They have not announced that yet.
