As you know, when there are certain issues that cause the Yarbo to suspend, like cutting disc issues, then return to the charging pad, a problem arises when the Yarbo is within a gated area causing damage to the gate. Instead of returning the the charging pad automatically, there should be an option to have the Yarbo suspend in place, that can be toggled on via the App when mowing within a gated area.
would be handy at times…
It would also be “handy” to receive a notification when a plan is suspended, along with the reason ![]()
Thanks for sharing your suggestion. I’ll make sure to pass this along to our product team for their consideration.
