First time use, large lawn had just been mowed by conventional mowers leaving the grass clippings. Yarbo started mowing a 65000 SQ ft area and finished the job. The tracks however were filled with dry grass clippings and these had also cleaned out the grease from the inside of the tracks. Suggestion to make new buyers aware that the lawn should be " clean" free of heavy grass clippings. This was the first main use of the robot and after that I had to remove the tracks and clean. Would it be possible to add something that keeps the dry grass clippings to enter into the tracks, a little brush maybe?
This is not uncommon for the machine and not a big issue. A leaf blower and a hose can get a lot of it cleaned up. It will be less of an issue when you are micro mulching, but still expect some debris around the track wheels. There is a scraper that will wipe away most of the debris around the track wheel itself. Adding a brush would most likely wipe away the track grease and cause more debris build up than what currently happens.
