Vibrating sound from mowing module
My mowing module has started making a rather loud vibrating sound. Has anyone run into this issue? I’m going on 5+ days with a ticket to support with no response. Very frustrating.
Shutdown the core, flip the mower module over and look for a missing blade or broken disc. Also possible you might have a stick or something wedged in there too.
Grass wrapped around the motor shaft? You might have to pull the discs and the disc mounts off to get to them
Tim
I’m sorry for the delay in responding to your ticket. I understand how frustrating it can be to experience an issue like this and then have to wait for a response.
In the meantime, you may want to try the troubleshooting steps suggested by Bryan and Tim.
If those steps do not resolve the issue, please update your support ticket with the troubleshooting you’ve already performed. This will help our team avoid repeating the same steps and speed up the diagnostic process.
I’ve also reached out to our team and asked them to review your case as soon as possible.
This is the exact same noise my unit made when the blades came loose. More than likely, at least one of the blades has one loose or lost screw and probably the plastic cap too.
You can see that here: Mower Pro blades came loose, anyone else seen this?
They don’t have a pro module, but it is definitely the same loud noises for either when you lose a blade.
Tighten the nut holding the aluminum plate the disc bolts into.
