Wet cuts are not advised!
I know you’re not supposed to cut while the grass is wet. But a long job lasted into the night and a heavy dew coated things up pretty good. The next day I decided it was blade sharpening day and decapitated Yarbie like Data in “Time’s Arrow”. I proceeded to turn him over and was surprised by how thick he was coated in clippings.
The underside looked like a glistening, flat putting green. Everything was caked in blades of grass - some around 1.5” deep. After a generous hosing down, blades were sharpened and returned to active duty.
If these clippings had remained on Yarbie’s underside and had a chance to dry, he might have suffered a blade “failure to spin up” type error or worse. Take heed. If the blades sound funny, check it out. Maybe your unit’s underside is coated in clippings.
Thanks for sharing this reminder! Wet grass can definitely lead to more clippings building up under the unit, especially after longer mowing sessions.
Regularly checking and cleaning the underside of Yarbo is a great maintenance habit and can help prevent potential blade-related issues.
Thanks again for sharing your experience and helping other users keep their Yarbo running smoothly!
