Which is better between ntrip or base center
I have a plot of land with many trees; which is better for GPS signal quality and reception: the ntrip option or the data center?
They both should be the same if your Data Center (DC) is installed per manufacturers installation instructions (clear unobstructed 120 degree view of the sky as high as you can go above the roof line). NetRTK will be a subscription at some point after 90 days, so I would stick with DC. The DC also doesn’t need your internet to be up for it to continue running a plan. NetRTK needs internet to function (over HaLow, WiFi, or Cellular).
