Twice now the unit has run out of battery (0%) while mowing and dies in the yard without attempting to return to the docking station. It is set to return at 15% which gives plenty of time, however this is a new and frustrating issue. It is not under trees and all *(yarbo, data center, and router) were reset prior to mowing.
Not sure why it happens to you but this option could at least allow you to drive it back to the charging station: Sleep on low battery - #7 by JNS
Dumb questions incoming…
If you look at the Yarbo’s main page in the app, does it continue to show 100%? There is a bug where that does (I’ve been looking at it for several mows today), and although it seems harmless and for me eventually shows the correct percent of charge, I’m wondering if in some cases it’s not just some kind of display issue in the App. Your battery sure should be going back to charge at the % you set.
Is it at all possible the rover took the remaining charge to try to get back to the Docking Station? I had that happen with the snowblower – it decided to return a bit late to charge, got too low to leave the auger on, and couldn’t clear the Pathway it was supposed to take, and the rover got stuck. oops.
I am guessing it suspended the plan for some unknown reason and sat there waiting for instruction and died. The question is why didn’t it send an alert when the battery was critically low. Or it could perhaps be the 100% thing you saw too.
When I went to check on progress in the app, the battery showed 0%. The battery percentage ran down as it should, but the device never turned for home at the low end.
So it was still mowing at zero percent?
Battery failure? Bad Cell? What if you set the percent to say 40% as a test to see if it makes it back to the docking station?
Thank you for sharing the details. This is an unusual issue and will require further investigation by our support team. We recommend opening a support ticket and including an estimated timestamp of when the issue occurred. This will help us look into it more effectively. We truly appreciate your patience and understanding as we work to resolve this for you.
For sure we need more control over alerts. There are some that I want to be persistent critical that need immediate attention. The only one I get reliably is completion of Work Plan. That’s great, but certainly not the most important.
Yeah they should just reprogram that one to be plan suspension since it’s so reliable.
I just had this happen this morning. It cut 25% of a large area and displayed 100% the entire time. Then it started rapidly dropping in few minutes to the correct SOC.
That is “normal”. Seen that from day one. I think @Ken was seeing 100% throughout the entire plan. That would be abnormal.
10:4. It was new to me. Mine has always tracked as I would expect.
Yah, I’ve seen it stick at 100%, and in looking back through my logs it’s mostly the smaller Areas. I thought it was far more chronic, not really. If you go into Work Plan History, there it shows a 700sq.ft. Area using 3%, 812sq.ft. using 4%. I don’t think the correct battery usage – which it obviously knows – is being updated in the display unless your mower sucks down some minimum amount of juice.
I’m to the point of ignoring it. Are you going to log a support ticket, @cobradunn? If you do, I can give you some deets from my machine so they can have two to look at.
Speaking of work plan history…. what does “Battery Cons.” stand for?
Well, a Battery Con for Li-Ion is the thermal management requirements, as we’ve all seen. Another Battery Con is
poof
. But we’ll just set that aside for now.
Ohhh, wait, you mean Consumption. Never mind.
Battery Consumption
Wasn’t planning on opening a ticket. It didn’t cause any issues and settled in on the correct SOC. I’d rather the resources get devoted to correcting some of the bigger items.
Consumption. Not super useful. You can determine how many times it recharged maybe. My fav is the Clean Area stat when mowing
How bout we add % Complete for Manual Stop plans. Then when I forget to look before I cancel the plan I have a reference.
