Got questions after the new update? We’ve got answers!
A: Yes — if the next schedule uses the same Work Plan, Yarbo will automatically continue mowing the unfinished area.
If you run a different Work Plan in between, Yarbo will treat it as a new job and start from the beginning when you go back to the old plan.
Yarbo keeps progress only for consecutive runs of the same Work Plan.
Q: Why am I seeing rollover & tilt detection, lift detection, and rain detection notices even though I’ve disabled them?
A:After this update, Rollover & Tilt Detection, Lift Detection, and Rain Detection are enabled by default.
You can simply adjust these settings back to your preferred configuration — once updated, Yarbo will remember your selections for future use.
A:You can find this option under Yarbo Settings → Safety Settings → Car Detection (Beta).
A:
When Vision is enabled:
Yarbo will visually detect obstacles and slow down as it approaches them.
Once close enough, it will make light contact using the bumper to navigate around the obstacle smoothly. -
When Vision is disabled:
Yarbo will rely solely on the bumper sensors for obstacle detection and avoidance.
Q: What will happen to my no-vision zone after the feature is updated with the vision zone function?
A: Your existing no-vision zone will be automatically converted into a vision zone with the “Use Vision” option disabled.
A: The camera view may be temporarily unavailable if your device firmware hasn’t been updated yet. Once the firmware update is installed, Smart Vision will work normally again.
A: Tow Mode is currently available only to a limited group of test users. The feature is still in testing and may need further improvement before being released to all users.
A:In some cases, the undocking path may result in an unexpected turn. We are refining the path planning logic, and a fix will be included in the next hotfix update.
