I now have had both of my yarbos stop mid mow. No apparent reason. Just stopped not moving. Hitting the green play button does nothing. The can still be remotely controlled and viewed.
Only way to get them to respond to continuing is to reboot it.
Once I had somewhat similar issue - yarbo stopped mid mow. There was an error, that left camera disconnected and no reaction to app.
Only way was to reboot yarbo with physical button.
No i have just yet for this unit but now it has progressed not mowing. Just sits there.
I’ve tried a reboot of everything. Forcing the app to stop and clearing cache.
Still responds to the app to drive, it will go recharge fine
I’ve been having the dreaded not charging properly thing this week to, but during the process of messing with it that resolved itself and the battery charge was at 42% and then next thing its at 82%!
On the dock the mower module is typically lifted slightly. What happens if you manually lift the mower a little after it leaves the dock? This could be another connection issue.
I got it mowing again. Ended up putting the M1 head on and it mows like it never skipped a beat.
I put the M1 on ant it spun up and started the job fine so I shut it down and put the pro on.
I was able to start the blades spinning so l sent it to the dock to to restart the plan I wanted to finish. And it never started again. So shut it down again sent it to the dock and it is happily mowing.
I was about ready to put my 3rd unit into service.
