[2024] How to Avoid Freezing Tracks on Your Snow Blower
Winter weather can be harsh, especially for those responsible for keeping walkways and driveways clear of snow. One common issue faced by users of snow blower, Yarbo, is the freezing of tracks after extended periods of use. This article will guide you through the steps to prevent this problem, ensuring your yarbo stays operational and efficient throughout the winter season.
1. Post-Snow Blow Maintenance
After each snow clearing session, it’s crucial to perform a proper maintenance routine to prevent the tracks from freezing. The first step is to clean the area between the tracks and the walking motor. This can be done by:
  • Turning off the bot and allowing it to cool down to avoid any burns or injuries.
  • Using a brush or a similar tool to remove any accumulated snow, ice, or debris from the tracks and the walking motor.
  • Inspecting the tracks for any signs of wear or damage that could lead to further complications.
By keeping the tracks and walking motor clear of snow and ice, you reduce the likelihood of the tracks freezing to the track, which can cause operational issues.
3. Lubrication After Every Four Charges
Regular lubrication is essential to keep the tracks moving smoothly and to prevent them from freezing. After every four charges, it’s recommended to apply lubricating grease to the tracks. For detailed instructions on how to apply lubricating grease, refer to the following resources:
Lubrication not only reduces friction but also creates a barrier that can help prevent ice from forming between the tracks and the walking motor.
4. Thawing Frozen Tracks
If, despite your best efforts, the tracks freeze, there are steps you can take to thaw them out:
  • Move the Yarbo to a slightly warmer indoor area, such as a garage or a shed, to allow the ice to melt naturally.
  • Avoid using any heat sources that could cause the plastic tracks to warp or the motor to overheat.
  • Once the tracks are thawed, clean and lubricate them again to prevent future freezing.
By following these simple maintenance tips, you can significantly reduce the risk of your snow blower’s tracks freezing during winter operations. Regular cleaning, lubrication, and proper storage can extend the life of your yarbo and ensure it’s ready to tackle the next snowfall. Stay proactive with your yarbo’s care, and you’ll keep your paths clear and safe all winter long.
