2025 - Fix the RTK Antenna Breakage Issue
I’ve now been involved in 3!!! impacts to RTK antenna whereby the auto-detection of obstacles doesn’t detect a trailer or low hanging branch. In each circumstance, the RTK antenna mounts are broken off, oftentimes further damaging the antenna wiring connectors. I’ve also had 1 instance of the HaLow antenna breaking off.
It is a major design flaw of the Yarbo core that the cameras do not have enough field of vision to correctly account for, and therefore avoid, these situations. Why would you have something sticking out the top of the Yarbo core that you can not protect against with software?
The answer I’ve received from Yarbo is that I need to always ensure I create new no-go zones each time I move something around my yard. This is not a sufficient answer. Yarbo must be redesigned to prevent these issues. I have had other autonomous mowers, each with a smooth back (no antennas sticking up!) that prevented any damage if the mower got into uncertain areas.
Please fix and then update all 2024 cores.
We are so sorry to hear about the issues you’ve been facing with the antennas. We understand how frustrating it must be to deal with frequent damage, and we truly empathize with your situation. We’ve noted your support ticket and will arrange for a replacement as soon as possible.
Regarding the design of the stick-out antennas, this is actually done to improve signal reception. We know that other mowers might have different designs, but for the Yarbo Core, which has a firm steel body frame, the signal reception can be weakened by the metal if the antennas are not sticking out. Therefore, we currently do not have plans to change this design.
We understand that the obstacle avoidance feature is crucial in these situations, and we are actively working on improving this with new technology. We will update you as soon as we have progress.
As a temporary workaround, you can try adjusting the no-go zone and obstacle bypass settings to help resolve the issue. We apologize for all the inconvenience you’ve experienced and promise that we are committed to improving the product for a better user experience.
Thank you for your understanding!
I agree with you that creating no go zones each time something changes or is parked somewhere (like your driveway) is just downright bad design. It’s shocking to me that the cameras can’t detect large objects like cars, trailers, etc… and just rams right into them causing all kinds of damage. Yarbo has to use the driveway in my yard to navigate to the front/back yard locations. It’s not an option to make the whole driveway a no go zone. I HOPE they seriously fix this issue and provide it to all current owners (whatever it is) at no charge.
@Yarbo-Forum unfortunately my rtk antenna got decapitated as well! too bad because yarbo was doing a great job. I reached out to yarbo support and they’re sending me a replacement antenna. I’m hoping to get it pretty soon and that replacement is not an ordeal. I guess I’ll be more careful about planning no go zones in the future
How long did it take to have them decide to send a new antenna? I’m going on a week and being told my case is under investigation after it collided with my fire pit, bending the frame and breaking both antennae. My Yarbo is non-functional currently because of it.
Can Yarbo look into flexible whip-type antennas? They can then be tall for signal, but flex out of the way when they hit something…
My yarbo just broke off an RTK antenna driving under a forsythia bush. That’s with the new app version 3.15.0 set to moderate bypass. Why don’t you make the antennas stronger or offer a brush deflector? This is just flimsy plastic–at $19 each!
what firmware version do you have 3.8.4 or 3.7.4?
3.8.4 I think it downloaded just prior to mowing that area because there was a long pause before Yarbo took off.
I lost all 3 antennas on my first go. Mainly due to low hanging branches. Ordered replacement antennas and came up with a plexiglass canopy:
Been running this setup for 2 weeks and really deep into the branches - so far prooved itself better then expected!
Just a piece of plexi on heavy duty zip ties. Make shure you leave some space for the antennas and the module adjustment. With this mod it can literally just dive under all the bushes and branches - antennas are safe and I haven’t noticed any signal issues.
Nice.
How are you managing the longer HALO whip?
This is what I was thinking and am wondering if there’s reasons as to why it can’t be this format.
Lost my RTK, and HaLow today because of GPS issues again.even thogh the location was in a no-go zone and obstacle bypass settings to help resolve the issue. It did work, Yarbo charged in anyway. I need the whole Kit for Halow ASAP. :expressionless_face:
This I may try when, and if I get some news ones sent out. Was thickness, and size plexi did you buy and use? This is what I’ve been talking about. Something that would just brush over the antennas. When they move houses in the city with low power lines. Someone stands on the roof, with a flexible board, or pipe so it brushes smoothly across the roof, and doesn’t get caught up on the eve of the house. So like a mushroom effect. Just like what you have going on. Thanks again for the idea, until they get this issue fixed. :wink:
Hi, I broke a RTK antenna on my first mow… Now my mower has been non functional for a week and havent event completed 1 job… Opened a ticket, it says “escalated” to level 1. I ordered a replacement antenna on yarbo.com (grass is growing and summers are short in Canada!) but the antenna has still not shipped. Anyone found an alternative to get the robot to work even if less accurate? Or anybody found an alternative third party antenna that works that can be shipped faster than waiting for Yarbo to send me one?
Thanks!
Take your broken parts with you to local hobbyist electronics store. Those are basic and popular parts. Most likely not in same length or shapes but they work ( if for example antenna has same frequency) and you will be mowing in no time again.
Or use Amazon to buy parts what will fit. I have post here how to lower the hight profile off the yarbo core. It’s all about new antennas.
Once yarbo has sent you replacement parts you can either switch back to originals or keep them as a solution for the next time this again happens. For sure it will…
Here is the post I was referring to.
You will be also most likely needing SMA female on one end and SMA male on the other end cable. 30cm is long enough and easy to install
Thank you. I found your post yesterday (thank you!) but the shipping time for all the similar antennas I found are more than 3 weeks… But thank you and I’ll keep looking for similar parts!
