I am going to show an inexpensive and very easy way to eliminate warn and muddy entrance to the charging pad. The 12 inch by 12 squares with cleats just anker themselves to the ground, and they snap together to make a stable smooth platform for Yarbo to easily swing around on. They can be purchased at Home Depot, and are made by Gogexx. I am going to try and add a pic of my setup.
Sorry, canāt figure how to upload a pic here.![]()
When you open the post window, there is a little up arrow in the formatting menu above where you type. Click that and it should allow you to select the picture you want to upload.
Thanks
Try copying it and pasting it into the text window. That always works for me.
Is it this one or one like it? I like this idea. I used large pavers, but this is a nice solution too!
Thatās a pretty cool idea. Iām still deciding how to do mine so this was timely, thank you!
Yes, you the best!
Thanks for sharing this with our Yarbo family! This must be really helpful for others who are dealing with the same issue.
My āsolutionā. So far so goodā¦rubber exercise mats with carpet pad underneath. Lots of screws with washers including the data center mount screws. Plywood piece is temporary.
I used a product called āRutGuardā. Itās a heave plastic mesh that grass will grow up through and almost disappear. It is used for grass driveways (cars) and comes on a 4ā wide roll of various lengths.
Would like to see a pic if you have one.
