My unit is throwing a rear camera blocked (CM007) error with the back brace mount installed. It seems to be working fine otherwise, and the view from the back camera isn’t obstructed. Thoughts?
Do I need to recalibrate with camera with the BBM installed?
No need to recalibrate the camera after installing the BBM. If everything else is functioning normally and the rear camera view is not actually blocked, you can continue using it as usual.
