Battery at 0% how do you charge it
What’s the weight? If around 90lbs it might be your mower module.
Mower is coming FedEx.
This one is coming from Riverside CA.
It’s 50 pounds… so not likely flexible antennas.
It’s a big antenna! :joy:
Extra flex
LOL… Turns out it was my workbench for the shop. It got here before my mower. :frowning:
The better to put those antennas on with
Now I need to teach Yarbo to jump up on the workbench. :joy:
Please let me know how you do that if successful. My back will thank you!
I heard a sad trumbone:(
Mower did arrive and I successfully mowed my one side of my front yard before dark.
I intercepted Yarbo headed to the charging station after it finished the first work area and sent him to a second work area.
He worked flawlessly on both work areas until his battery went to 20%. Then he couldn’t find his way back to the charger due to me deleting a pathway that I forget to re-map. But hey a quick pathway and back to the charger. Await on the dew to dry before sending him back out to finish the second work area. 5 more workareas after that. Wish me luck.
Awesome. User error gets ya every time. :joy:
How’s it looking? You’re grass was pretty long.
@ken.w.gregory - Plop it in a weak GPS spot and start any Work Plan. It’ll climb up anything – backwards!
Not too bad actually. There are some spots but Yarbo is working through it.
2nd mow should clean it up. Soybeans are looking good though :slight_smile:
Beans are indeed looking good.
I think I have finally figured out how to mow without issues.
  1. Have Grok write an app to take a screenshot on an interval.
  2. Start Yarbo app.
  3. Start the screenshot utility to take a screenshot of the Yarbo app every 15 minutes.
  4. Enable Record Issue in Diagnostics.
  5. Send Yarbo off to mow a work area.
So far it’s working. NO ISSUES occurring. :wink:
Not even kidding a little bit…
I like the approach. Never need to worry about lack of details about what happened and you scared Yarbo straight.
Using an NLM to cure Heisenbugs was not on my 2025 calendar, lol
