Best Garden/Utility Trailer for Follow Me Mode
I already have a 1500lb capacity garden trailer but the from wheels are NOT on a pivot and more designed for my side by side. I am looking for a larger garden/utility trailer that people have used with their Yarbos. Want to use the follow me mode for spring/fall cleanup. Figured I would ask from anyone’s previous experience and if you could share any links to said suggestions I thank you in advance!
Anything that does not have any tongue weight (e.g. you want four wheels).
If it’ll side-dump, even better, since follow-me does not have reverse.
As @steve says – four wheels, but at the corners. Some carts (CLAM/Polar) have 4 wheels in the middle – I would assume the tongue weight would be an issue there.
I have a large 2-wheel CLAM cart and use it with my rider. I’ve used it with the rover, and it’s a bit touchy with the weight balance, which you have to get right. I’d have to get another wheel and put on a flexible hitch bar to use with the rover.
Instead I bought a large Gorilla cart with a convertible handle to use with the rover. Unfortunately that big but shallow Gorilla doesn’t let you stack things up to hold a lot – ironically – and someday I’ll have to put sides on it. It’s got huge wheels, making it really easy to move, but it’s not very deep.
Yes, the current Tow Hitch is not difficult to snap, so you have to be careful with it. The new one coming soon should be far more robust.
I also have the gorilla wagon. It is pretty shallow but I use that to be my break time reminder. :wink:
Wagons full, Break Time!
And yes, the tow hitch is easy to break. Yarbo got of into the flower bed and was break dancing which didn’t end well for the hitch.
Here is my adventure with Follow Me and Waypoint Navigation.
Kind of nice you can do a waypoint on a pathway. I have a pathway that traverses my driveway (Net yet mapped for now blowing) and passes in front of my garage. I drop the waypoint in front of the garage and have Yarbo navigate there. From there I can drive Yarbo into the garage for maintenance.
Hope the suggestions from our warm community have been helpful! As others have mentioned, four-wheel carts are definitely a good option to consider.
Just a kind reminder: for loads over 100 lbs, we recommend using a ball hitch to help prevent any potential damage to the official tow hitch.
Hope this helps!
This thread provides useful insights on garden utility trailers. For businesses managing multiple trailers and equipment, implementing a trailer yard management system can streamline operations, track assets, and improve overall efficiency.
Guess your using the hitch pin with no issues as appose to the recommended ball hitch?
