Brand new Yarbo and setting everything up. Have installed Data Center check and have EXCELLENT Coverage! Charged the Yarbo overnight via the hard cord charger and NOT the pad. Unplugged the charger this morning and turned the Yarbo on. Upon start up the Core says “Start Charging” if I look in the app the Yarbo Core looks like it is still charging event though it is 100% already and if I tap the “End Charge” I get a message saying “Wired Charging - Your Yarbo is currently charging via cable and cannot be stopped through the app.” I have tried restarting the Yarbo through the app and the Safety Setting area. I have also tried unplugging the battery waiting for 30 seconds re-plugging the Yarbo back in and same thing happens. So not a really good first experience but unable to proceed further.
With Yarbo powered on have you tried connecting and disconnecting the charge cable?
I think this will be resolved when your firmware update issue is resolved.
Have done that process. Contacted support and waiting on an over the air firmware update but standing still until then.
Mine had to sit overnight as well. Hopefully they hit you quick.
Did you leave yours charging while waiting. Since i have not yet installed the charging pad I was planning on leaving it on so it gets the update but didn’t know if I can leave the rover on while charging.
Yes, you can leave it on while charging. It charges while on on the charging station. The BMS should handle not overcharging it.
Yes. It should be plugged in or on the dock while waiting.
