Hotfix Update: Firmware V3.14.11 & App V3.19.5
The thing crossed NGZ again … and got stuck with it’s belly on a rock…
Previously never saw it going so deep in NGZ
Maddening how it starts in the tightest toughest spot in your map too.
Ouch. That looks like a significant intrusion into the NGZ. Not good at all.
Of course support can always blame on PPVS as there are some trees, but they are nowhere as dense as in some other areas … but in those all the NGZs are the trees themselves which cannot be crossed because of the tree trunks :grin:
But hey - I hope PPVS is not simple “trust me bro, I’ll just blindly drive straight” approach.
Sorry, I don’t recall - Did you have the ultrasonic sensors and object detection active?
AI powered intelligent robot mower…
plus the placement of the start point (green dot) between two NGZ less than 4 ft apart.
Was prompted to install the latest firmware as I was running a workplan. I did it and now I cant start a plan. Nothing has changed. worked prior to update.
Why cant the software just get good…
Do I just wait? Correct map drift? reboot it again?
Unplug data center and battery cable for 5 mins. Plug in DC, then core. If it doesn’t correct after a few mins when booted, Manually drive it out into an open area and wait. When you see green GPS, try again to start your plan.
If your core was sitting in marginal GPS area, you’ll see this and won’t be able to start a plan. Can you share more details?
Can you manually drive it to a place with better GPS? Can you use vision to see where you are going if you are remote?
This was mine today on the latest firmware.
Ouch! How far into the NGZ did it roam?
I have been running V3.14.11 non-stop for 2-days now and am successfully completing plans, which is good if you have low expectations. Fixing a few select regressions from recent releases isn’t real progress in my mind. We are basically back where we started when PPVS was released. It still repeatably misses grass - especially on turnarounds, completely skips stripes in routing, enters NGZs at will, and fires off completely unwarranted zero turns. I try to be positive but Yarbo makes it hard.
This should not be happening! Crazy that this thing has been out 2 years now and it does stuff like this!
Ridiculousness. Looks like a route mapped directly to the center of NGZ What kind of math allows this?
Alex Wassabi's Math Confusion
3+9=7 new math
It’s not pro. So no ultrasonics I guess …
But yes - I have vision + gentle contact. The thing is - these rocks are not high enough to touch the bumper.
Really sorry for the inconvenience this has caused. We’ll take the issues you mentioned seriously and continue investigating them through your support ticket.
Once our team has any findings or updates, we’ll keep you posted there as soon as possible.
