Mapping my yard tips
Yarbo Team,
I am initially mapping my yard and would love to have any tips you have. My front yard is broken up left to right by my driveway.Should I map the left and right grass areas separetly oras one big area including the driveway. Same scenario from treelawn to front yard on both left and right sides.
Not sure how to factor in my driveway or sidewalks. Also what is the best way to have Yarbo turn on my driveway, instead of the grass to help prevent damage.
Any initial yips you have would be greatly appreciated.
Scott
I would map them as separate areas. Turning on your driveway to minimize damage is a great idea in theory, but if you can’t be certain and fully control when and if traffic is going to randomly be on the driveway, then I would advise against it. Car detection is still in beta and honestly Yarbo may zig when it should zag causing a delivery driver or someone else to collide with it.
As for mapping, keep it small and learn the robot first. Don’t go map your entire yard. Play with it, learn it, tweak it and then be prepared to delete your map and start over with your new found knowledge. Use the natural boundaries on your property as areas at a minimum and I think you’ll be happy with the results. You can tweak and break it up further if you have complex scenarios or something else you need to mitigate for or tweak.
Top threat to every lawn bot, ever:
A moving car on a driveway.
Try to avoid ever crossing a driveway. If you must, then you must. Otherwise, go completely around the house if you have to. You think your spouse will watch for the robot, and they will. They’ll see it across the lawn and put it in reverse, and then they’ll hear it crunch under the car. Or the FedEx guy, or Amazon guy, whatever. Every lawnbot has a car detector, and the first thing the bot does is drop everything and head directly toward it. Yarbo’s collision avoidance looks “down”, not “up”. And that applies to everything.
If you are trying to map an area that loses GPS, just skip that dead zone area. Map the rest, tune that, and come back later. You can try to add more of that dead zone piecemeal, and prove the robot works reliably in that addition. That’ll put the robot on the edge of what can and cannot work, instead of sending it 200 feet into the void.
Do not try to be accurate around hazards. Give them a wide berth. You tighten things up once you learn the behaviors and caveats of each specific area and mowing angle. Mowing a plot with a 35 degree angle can be completely different from mowing it at a 70 degree angle. And it changes, yet again, when the morning sun is blinding the cameras, vs mowing in the afternoon. Vetting the behavior of the bot in an area takes time.
There’s an instinct to get an area’s plan perfect on the first try.
Ignore it.
Protect the robot from things in the yard, then expand the robot’s area once you see where and how it screws up, vs where it doesn’t. It takes time to do that.
These things are awesome, but become less so when it decides to bushwhack through the woods, take out your kid’s play set, suicide under some stairs, or drive into a 12 foot ditch. If you pay out your areas carefully, you can probably avoid most of that. As long as YOU avoid such things, you’ll be smiling. If you expect it to start threading needles, you probably won’t be.
Hello Scott, welcome to the Yarbo Forum!
For your front yard mapping, we’d recommend mapping the left and right lawn areas separately. This will give you more flexibility later when setting up work plans or making adjustments.
If you’d like Yarbo to turn on the driveway instead of on the grass (to help reduce lawn wear), you can slightly extend the mapped boundary into the driveway when creating the area. After that, you can preview the route and fine-tune the route angle so that the turns happen along the edge between the grass and the driveway.
That said, if your driveway is frequently used by cars, it may be safer not to include it in the mapped area to avoid any potential risks.
Hope this helps, and feel free to reach out if you have any other questions!
HELP,
Yesterday
I got my data center installed and have a solid green light. I installed my dock, and drove my Yarbo to it, configured it, and it parked itself perfectly and began to charge. All good.
Today
I opened up the app, connected to my Yarbo and then hit Create a Map, Iget a pop up message that reads DISCONNECTED, Device GPS is weak. I then checked the data center to see how many satelittes were connected and it varies from 19-25.
So I rebooted the data center, and then rebooted the Yarbo and I get the same results.
What am I doing wrong?
HELP, I really need to get this thing working!
Here are screenshots
Here are screenshots. Help
Yesterday
Today
Tap details there under RTK and connect to your DC and let’s see a screenshot of your CNR values. Also, can you scroll down in diagnostics and capture Status, Data Center, and Halow sections? Your quality is low currently and HDOP is high. This leads me to believe either your DC or Core are obstructed. Let’s rule out the DC first, but if the core is up against a building or something, this could explain it. GPS satellites move and the time of day can impact signal quality for the better or worse.
I will move the data center above the roofline. Here is the pic you requested.
While those numbers do look good, I think you’ll have much better success overall with it above the roofline. There will definitely be less quality issues from reflections. I’d also move the core out at least 7ft away from the house. That will help also.
I moved the data center up. I think it’s good. Will map tomorrow.
If you didn’t, do a reinstall DC in the app before you start mapping since you moved the DC. It will still be initialized with your old coordinates. Also, if you haven’t already, make sure its firmware is up to date. If you have that support plastic bar for the HaLow antenna, I would recommend putting that on too.
After you try repositioning the Data Center, feel free to keep us updated on whether the GPS signal improves. We’re more than happy to take another look and help you troubleshoot further if needed.
I I reinstalled the data center. It’s connected to 21 satellites. I’m still having GPS issues. I drove the Yarbo out to the middle of my backyard and opened space and still cannot get it to connect the satellites so I can map. I also powered off and on both the Yarbo and the data center. Frustration is setting in and any help that you could provide would be greatly appreciated.
When the yarbo is out in the middle of the yard with a clear view of the sky, what does your diagnostics look like?
Bryan,
So I moved the yarbo out to the middle of the yard and the satelitte connection was strong. When I re-docked it on the station the GPS signal drops. I repositioned the docking station further away from my house and wellah - strong signal. I am going to try to find a better place that is not out so far from the house, but can live with it’s current position for now.
So I created a quick map for testing purposes, then drew the pathway from the dock to the mapped area.
I redocked Yarbo and now I need some help on how to send it out to the mapped area to begin cutting the grass. I cannot seem to find that. Do I need to create a schedule? How do I manually tell it to go to the mapped area and cut the grass?
Lastly, when I manually run it and turn the blades on it hums, but not very loud at all and it does not seem to cut the grass very well I will play with the height adjustment a bit, but I noticed that when you select a low height it warns you that it may damage tghe machine.
Truly appreciate your help.
You’ll need to do the following:
  • Check/set Work Preferences. (Battery Charging levels, etc. )
    • Setting gear at the top→Work Preference
  • Set the configuration of the mapped area.(Things like mowing height, speed, pattern etc.
    • Setting gear a the top→Area settings
  • Open the Yarbo App and select your Yarbo. Press the (Yellow) play button at the bottom of the screen and create a work plan by hitting the + icon. A work plan groups mapped areas into a single “job”. You can set the order in which they run by drag and drop. If you’ve only have one, just pick it and go. Once you’ve selected the area(s) name the plan and run the plan.
And let the fun begin!
Glad that worked out! Follow @ken.w.gregory’s advice and let us know if you have any more questions or issues. As for the cut quality, if you have cool season grass and the standard razor blade model mower, I’ve found it needs to be at least 3 inches or less. It also may take several cuts to get it looking good and then as long as you send it out at least twice a week to maintain the cut, it will keep it looking nice. Robot mowers are maintainers not like a traditional mower that can remove a ton of material at once. The mower pro is an exception. I find that can do a nice job at about 3.5 inches or below.
Yarbo,
When I navigate to Safety Settings in the app, I do not have a toggle for Person Detection. I would like to turn this feature on. Can you assist me with how to accomplish this?
See Pic.
I made anew post on this but it is still pending?
What module do you have installed?
