Moving Trailers
In theory with the tongue weight adjusted it could tow that briefly on flat ground. I’d consider the BBM for it long term if that’s your plan. It’s not designed to do that load daily though. Here are the specs. Also keep in mind the robot with module is only around 200 lbs, so no braking or ability to resist that load pushing it.
