Mower Pro leaving 4-6" gaps?
So I went out and watched it through several passes. Yarbo is going down and back on the same path, then moving over 6-8" and going down/back along that path.
Hence the leftover stripes in the yard.
This is with checkerboard pattern and a 4" overlap as settings. Smart turns selected.
That is odd. Does it show the pathing correctly in the app?
It does. According to the app its mowing correctly, but in actuality its mowing as I described.
I assume you’ve done reboots on everything?
On the DC, the Yarbo I believe has just been restarted from the app. Is there a more “thorough” reboot I should try?
Reboot of the rover, which it sounds like you did. I haven’t seen this one before. It definitely shouldn’t be behaving like that. Let’s see if anyone else has suggestions. I would open a support ticket if you haven’t already.
@Yarbo-Forum
I’m up for ideas from anyone who has them. I just unplugged the battery from Yarbo for a few minutes to make sure its rebooted.
I have not heard or seen of this behavior before. Definitely odd. Maybe you can capture video of the rover doing it and screen record the app? That would definitely help support try and figure out what is going on.
And yes, unplugging the battery for 5 mins is a very good way to shake out some gremlins. Let’s hope this fixes the issue for you.
I unplugged and restarted, now Yarbo wont connect to GPS. DC is still picking up 26 satellites but the Core wont connect
Unplug the DC for the 30 seconds.
Ya I did. Same result, no GPS. Going to let it sit a few minutes and see if it connects
I wonder if he accidentally received two of the same kind of blade? Like two left blades.
Its not the blades, there’s a right and a left checked em this morning.
The core wont connect to GPS after a reboot, wonder if that has something to do with it?
Mind posting your diagnostics screenshots again?
He’s watching it duplicate the same path then skip a run.
Your quality is zero. Didn’t you have this problem before? Is PPVS enabled?
I did. Yarbo sent a new data center and the signal picked up green. PPVS is on, I can turn off and see if it resolves (so many settings I don’t have them all figured out yet).
Fancy that, GPS is back. Funny it worked for 3 weeks with PPVS on but stopped this morning.
I’ll have to watch Yarbo again and see if that also resolves the striped mowing.
I’d get a ticket opened on it though. Get in the queue just in case.
