Network and GPS issues after headphone
Hey all
I bought a new 2.4 MHz :headphone: and apparently it’s transmission range is sufficient to strongly interfere with Peckerhead.
Put the :headphone: back in the charger and problem solved. Lesson learned :wink:
Are you using WiFi on your core? That doesn’t make sense otherwise. HaLow is in the 900Mhz range for US.
Sometimes it does but most of the time it’s Wi-Fi.
Bryan is spot on.
Try turning off WiFi on your core, and you should be good to go with your Bluetooth music.
The HaLow connection should be much more robust than using WiFi anyway.
and no one, I mean no one will comment on the name of @laudav1285’s Yarbo core … no one … LMAO ….
Lol. You’re going to have to explain it to me. :rofl:
@laudav1285 - “I bought a new 2.4 MHz :headphone: and apparently it’s transmission range is sufficient to strongly interfere with Peckerhead.”
LMAO. I get to spend the money on toys but my wife gets to name them. I’m Peckerhead Jr. I think I should be insulted :wink:
It was cold outside! :joy:
Terms of endearment for sure, it’s always the little things.
