I have a warranty replacement core and docking station.And I have matt drift.I can’t correct it because it doesn’t see that it’s on the docking station when it is thoroughly on the docking station.How do II have a warranty replacement core and docking station.And I have matt drift.I can’t correct it because it doesn’t see that it’s on the docking station when it is thoroughly on the docking station.How do I fix this
I think this is probably an issue with the app being updated and the firmware not yet. Let the battery drain off the dock until it’s about 90% or below and then try putting it back on the dock, start charging, and then correct for map drift.
You may try following Bryan’s suggestion—let the battery level drop below 90% and then attempt the map drift correction again. This has helped in similar cases.
If the issue still persists after trying this, please keep us updated and we’ll be happy to assist you further.
