Odd charging pad behavior
Charging pad noticed my charging pad acting odd. It’s doing green blinking for about 10 seconds (charging) then goes blue, then will go back to green blink. Yarbo app shows yarbo charge, then stop, then charge again.
Wondering if others have encountered this while I wait to hear back from support.
Yes. This means that the rover is misaligned with the charging pad, but only just slightly. It’s close enough that it thinks it’s there, but far enough off that when it goes to actually kick on the power, it can’t do it.
Make sure it is lined up centered between the 2 yellow lines on the sides of the dock and the metal bumper aligns with the yellow line at the rear of the dock. If it is still cycling charging, then I’d try a battery disconnect for 5 mins.
Hi there, I’ve checked your update in the support ticket. Our support team will further investigate the issue.
We kindly ask for your patience while our team gets back to you.
