Back to disconnected.
I think I have a loose wire because sometimes it’s pixelated looking as well like a partial connection.
Your right and front have the latest for that hardware. Pixelation could just be compression and bandwidth throttling/adjustment.
Lol and the right camera is my problem child
At support’s direction, I unplugged camera from motherboard and reconnected. So far the camera has been stable now for about 3-4 days across mowings, restarts, and charges.
I’ll have to keep that fix in mind.
The FSE did transfer the maps for me. I’ve been playing catchup to get the yard back to manageable height again but it is working.
Target height can help here. It sets the cut at 4 inches and gradually decreases the cut height down to your desired setting over 5 cuts. Also, doing checkerboard or another pattern that rotates by at least 45-90 degrees alternating between cuts can help get it all cut back down and then maintained.
I have the same issue as you with the right camera. Did this solution work out in the long run?
Hi @jmlert ,
Could you please submit a support ticket for this issue? Our support team will be able to help identify the root cause and work with you to get it resolved.
It worked for about 2 months then went disconnected again. Now the camera works intermittently.
