Snow Trowing direction to a no-go zone
Hi all,
Not sure if this is requested already (cannot find it).
See attached image. I have a roundabout on my property, hence the no-go zone in the middle (plants and trees).
I cannot select the no-go zone as a snow-throwing direction. I could solve it with cutting the area in 2 but I think that it would be generally easy if we could also throw snow in a no-go zone.
You could even create a no-go zone on your parking lot to accumulate all the snow. Or does someone have another idea?
I’m having trouble seeing the attached image. :wink:
Happens to me all the time. Uploaded.
I see what you’re talking about. Unfortunately I think the only work around is the one you identified. Split the work area and mapping around the roundabout.
Maybe a sidewalk approach? Gets mess fast….
That’s just cruel, they even tease you with the ability to add snow throwing direction.
RIGHT!?!?!?! So annoying :sweat_smile:
Hahahaha… they made a lot of promises. But it is just a small thing. Not so important. I will just cut the plan in 2.
I asked for a check box on NGZs to receive snow/blow or reject snow/blow AKA vehicles.
I would say it shouldn’t be ignored. Separation from the pack is paramount. The faster the separation from the pack the better.
Implementing logical additions and programming tree extensions that complement and enhance work flow and efficiency. I can’t stand that the sidewalks make me reverse. Sometimes I want it sometimes I don’t.
This thing is a beast all the way around but there are some real head scratchers as if no one ever observed the unit preforming a work plan.
You mean exit the end of a sidewalk like it was a pathway?
Sidewalks don’t make you reverse out of them.
You can choose between backing out (driving backwards) or zero turn.
Seems like the logic for throw direction is on a NGZ, it just needs to retain the setting and actually do it. I like the suggestion of turning that on or off and when off it becomes a NO THROW ZONE.
The other option I think might be useful for this situation and I know I’ve heard talk about it before is to be able to tap a point on the map and have it deposit the snow there (or in the general vicinity).
Yeah. And then on to the next sidewalk .
Side walk 1
don’t return to start to continue to side walk 2
Side walk 2
don’t return to start to continue to side walk 3
Then at the end of side walk 3 reverse or zero turn back the the start of side walk 1
So each side walk doesn’t have a “down and back “
More like a “down and next”
You could toggle on the side walk do you want it to come back or proceed to next sidewalk.
+10,000 :wrapped_gift:
Gotcha, that makes sense.
Hi there, thanks for bringing up this topic. I’ve gone through the discussion here, and this is definitely valuable feedback. I’ll share it with our product team for further evaluation. Thank you for the great suggestion.
X2😁 great thinking in here
I just went to preemptively put no-go spots for the garage house porch etc… we could also use a way to edit the no-go areas after initial creation and saving​:+1::+1:
Exactly what I need.
