My Yarborough was working pretty well, but after updating to V3.14.20 my GPS goes from 0 to 326.70ft. It sometimes switches back to 0 and drives a foot or two before switching back to 326.70ft and stopping again. I restarted the RTK and the YARBO, but that did nothing. Right now, I cannot use my Yarbo.
Unplug the battery cable for 5 mins along with the power cord to the DC for the same 5 mins. Plug in the DC, then the core. Hold the power button for 60 seconds when turning it on. If that doesn’t resolve the issue, please post some pictures of your diagnostics (RTK, status, data center, and HaLow sections).
Hi there, really sorry to hear about the issue. I’ve checked your support ticket and confirmed that we have initiated the replacement parts process for you.
Please keep us updated once you receive the replacement parts and let us know whether they resolve the issue. We’ll continue to assist you if any further support is needed.
Having a similar issue that started about a week in a half ago right after the 3.14.20 firmware update. Was there a fix?
Care to post some pics of your diagnostics? RTK, status, Data Center, and HaLow sections.
This was from the initial time it happened, since then, I opened a ticket, a new RTK antenna Pro was sent, I installed on the data center, restarted the data center, restarted the Yarbo. The gps zero’d, I started running a plan, and within 20 min, the number started climbing again and the Yarbo stopped. I have to manually go out, drive it in, and when I restarted it again, it started up with this same value of 326.70. I’ve used the Yarbo since late June, no issues until this firmware update.
Have you tried switching to NetRTK to rule out the DC? Is your DC firmware up to date? Save your maps before switching, just in case. Be sure and correct for map drift afterwards.
Just tried, gps showed no change. Restarted Yarbo and still no change.
DC version is currently v1.1.11 (latest) based on the app
Do you have an active support ticket? If not, I’d get one open. Drop your ticket number here for the forum moderator to follow up on.
Had one previously, but they closed once they confirmed shipment of the antenna. Opened a new ticket #248570 and referenced the previous ticket from this as well.
Do you have the Pro Antennas on your core as well? One of those could be the issue based on those numbers. If you swap the left and right core antennas does anything change?
Hi there, I’m really sorry to hear about the GPS issues you’ve been experiencing. I’ve checked your support ticket #248570 and confirmed that your case has been escalated to our FSE team for further investigation.
I’ve also reached out to the engineer handling your case and asked them to prioritize the investigation and work toward a resolution as soon as possible.
