Whyyyyy!?
This is the second time in a row that Yarbo has skipped at least one row in this area.
I sincerely hope something is done to correct this problem soon.
Please put in a ticket for this, they will fix asap, lol.
I get it, same thing is happening to a lot of us.
Happens to all of us. Another routing bug that never gets addressed. Opening a ticket is all you can do. It’s a WELL KNOWN issue!
Those un cut strips just ruin an otherwise beautiful looking lawn.
I know this has been ongoing for a while now. I just had to vent cause it was really irritating when I saw it happen twice in a row!
Edit: And yes, I opened a ticket. Hopefully they will resolve this issue soon. :slight_smile:
Well hopefully you rotate your cuts by 90 degrees and can send it again to get it cut. Shouldn’t have to, but…
Last time, I manually controlled it and cut the missing strip. Guess I’ll be doing it again this time too.
You get some Yarbo time!
My wife thinks I’m taking it for a walk since we’re so attached :slight_smile: … to my wife of course.
Adaptive should offset the path plan*
*If configured :sweat_smile:
Default offset of 10 degrees isn’t enough to get around the path planning bug or get all the missed grass. 45 degrees minimum is a good bet.
Hi there, I’m really sorry for the inconvenience caused. I’ve checked your support ticket in our system. Could you please provide the information our support team requested and let me know once you’ve done so? I’ll help escalate your case to our FSE team for further investigation.
@rgloverii is it the same strip of grass every time?
Man, that’s annoying. Skipped rows ruin the look. Hope the ticket gets it fixed fast.
No, it seems to be a random stripe of uncut grass.
After adjusting the cutting angle, the uncut stripe disappeared. Who knows.
Have you tried putting a NGZ around that stripe?
Just sayin, but it’d work.
I am thinking that would only get you about 5% of the stripe completed.
