Wire Covering Installed
Most likely. Unless it happened to back it up during the firmware update (assuming that happened after).
I mapped with the older firmware and successfully sent Yarbo home to charge. It did get to the charging station and started charging. So in theory the map went to the cloud right?
I also feel like the failure mode is weird. Why would it let the smoke out while sitting on the charger charging.
Battery state when I went to look for the source of the smoke.
Should I try charging with the charge able? Will it boot at 34 volts?
Maybe the wireless charger fried.
¯\_(ツ)_/¯
If you smell electronic char, then I wouldn’t charge through the core. If you do have the battery charge cable accessory, it couldn’t hurt to charge it up and maybe see what happens while you wait.
I’ll throw it on the charge cable tomorrow.
Mine fried while sitting on the charger. The board wasn’t sealed properly and water leaked in while it was charging. I just happened to be standing next to it when it happened.
