Couldn't Help but Notice
Yes. I do not have many hours on Yarbo and noticed the leaves started to accumulate inside, so this cover will definitely helps.
@Yarbo-Forum I watched the video that @ken.w.gregory posted. Seems pretty straight forward. I see what you mean about the cables.
How liberal can we be with water cleaning out the inside of the core-keeping the speaker in mind? I’d like to get it as tidy as I can in there before the install.
I plan on avoiding water. Leaf blower will likely do a pretty good job, then maybe a damp cloth.
I just use my handheld blower. Works wonders and gets all the leaves/dust/debris out pretty quickly.
Hello Ben, I’ve checked with our field service engineers. It’s fine to use a damp cloth to clean the inside of the core. Just make sure not to spray water directly into the speaker area,
@Yarbo-Forum…
For some reason, my ticket disappeared from your system. I just had a new ticket opened, which is 132057.
Thank you.
@Yarbo-Forum I finally got around to making my ticket… #132069. Thanks for offering this
Thanks for the update. I’ve checked our system and can confirm that your case has been escalated, and we’ll be sending the part to you.
Thank you. I appreciate you looking into it for me.
Installed!!! Looks real nice. @Yarbo-Forum thank you for helping send the parts along. Much appreciated.
Nice! Much better. Should significantly help with the longevity of the components.
I hope Yarbo offers this retrofit to all of their existing customers.
How can one obtain this protective part? @bryan.wheeler @Yarbo-Forum
Just open a ticket or send them an email asking for it. Mine just arrived today.
A template of what to put in the ticket is here. Wire Covering Installed
Thanks Ken, I opened a ticket.
#132907
Received. Thank you.
Actually I just thought of a possible pro/con, it might help keep heat in a bit in winter, that might be a con in summer though
My experience was the opposite. The first core received in August had this plastic bulkhead but the replacement core received end of October did not so we transplanted some parts. Our 3rd core did have it fitted
No 2 are alike
So hot in the summer.
I’m going to guess that they tested this & figured it didn’t add enough heat to be a concern
