Feature Requests: Progress Report and Community Engagement
Hello everyone,
Since the launch of our forum, we’ve received a wealth of valuable feedback in the “Suggestions and Feature Requests” category. We truly appreciate your ongoing support, and we want to assure you that your input has been shared with the relevant departments for further consideration.
We understand that you may be eager to know the status of some of these feature requests, and we’re committed to keeping you informed. To ensure transparency, we’ve decided to share the progress of the feature requests that have garnered the most attention in the forum.
We will provide updates for feature requests and suggestions based on the following criteria:
  • They have received more than 50 views or 5 likes.
  • For feature requests that we do not plan to begin developing within one year, their status will be marked as “unaccepted.” However, we will keep these requests in our archive and revisit them if they continue to generate interest.
Every Wednesday, we will update the chart with the latest status of feature requests and suggestions from the previous week. (This gives us time to check with the relevant department regarding the progress of each request.)
We also kindly invite you to click on the links of the feature requests that interest you and give them a like. This will help us understand which features are most important to you and assist us in prioritizing development.
Feature Requests Status Note Topic Link
Turn lights on/off Accepted Scheduled for Release 8 Turn lights on/off
No Perimeter Lap Options for Work Area in Yarbo Lawn Mower Aceepted To Be Scheduled M1 Perimeter Options
Follow Pattern Lines While Moving Between Different Points Accepted To Be Scheduled Yarbo should try to follow pattern lines when moving between different points
Go-zone Featrue Added to the Request List To be considered for future development Path areas
Set Starting Point Manually Added to the Request List To be considered for future development Set starting point manually.
Security Function Added to the Request List To be considered for future development Security request
Gate Feature Currently Under Review Add "Gate" functionality
Landscape Mode - App (Tablet, etc) Currently Under Review Landscape Mode - App (Tablet, etc)
View Camera While Yarbo is Performing a Task Currently Under Testing Smartvision (Beta)
API access Accepted We are currently focused on optimizing the Yarbo lawn mower. Open API access will require careful attention to safety and privacy, and we plan to explore this further once additional development resources are available after the mowing season. API Access
Directly Edit the Existing Map in the App (Within the Current Map Range) In Development User Map Edits
Garbage can attachment Unaccepted Due to limited resources, we’re not going to consider this attachment in the short term. Garbage can attachment
a deadend path without the reversing step Unaccepted This feature is not prioritized at this stage(The purpose for a deadend is to let it reverse without making turning) Manual pathing (i.e. deadend without reverse)
Thank you for your continued support of Yarbo and for helping us improve our products!
Best regards,
Team Yarbo
Just curious if you can tell us how the testing on the viewing module while working is going and do you think we may see it soon???
We’re currently testing this feature with our PPP users, and the release timing will be determined based on the feedback we gather during this phase. We truly appreciate your interest in this feature!
Does anyone update this list….some of the things are completed on here like the vision….people think your still working on these items… very misleading
The list has now been updated.
I use the Suggestions and Features main page to view the status:
Also this should probably be marked “as a solution” :grin:
Edit: Realized the screenshot didn’t have a link to the board: Suggestion and Feature Requests - Yarbo Forum
Thanks - I was looking for this post last night out of curiosity when something was added to the list.
