Firmware V3.12.0 & App V3.17.4 Release Notes & Feature Highlights
Yes; while charging - blinking Green; then fully charged ( or no charge) as Blue. But I’ve never seen blinking BLUE before. I am still a new to Yarbo. Have you seen blinking BLUE light on the docking station? Just curious.
What did the app say while it was blinking blue?
It says “charging” but number showed drain. So went out check the Yabo and dock. I thought that subtle off alignment (skewed, not as straight as before the update) caused this issue; so moved over aligned straight and right center to charge; then it was blinking GREEN and the app says “charging” as before, but this time actually charging up!
Yep - as long as the app shows charging that’s normal. I think it’s a discharge state of the battery. Otherwise, it’s when it’s initializing or it shifted.
Got it. Thanks! I don’t know exactly how long blinking BLUE, and while blue flash, the app said ’charging’ no other error code. But definitely it was discharged with blue flash and “charging” screen.
Hi there, thanks for sharing the details. I’ve checked your support ticket in our system and can confirm that it has been escalated to our R&D team for further investigation. They’re currently looking into the issue, and we’ll follow up as soon as we have an update. Thanks for your patience.
Could you please share a bit more detail about the issue you’re experiencing? Based on the information provided so far, we’re not able to confirm the root cause yet. Any additional details—such as screenshots, videos, or a description of the scenario—would help us investigate further.
Hi there, thanks for the detailed information. Based on our initial analysis, there may be an issue related to the snow blower module. We’re still investigating to confirm the root cause before drawing a final conclusion. We appreciate your patience and will keep you updated as we learn more.
In the latest update, we added area labels as a factor in route planning, so the route may behave differently than it did before.
I was slightly mistaken. The snowblower mode does allow for zero turn vs reverse back. But, I was expecting to see the same for the plow mode when setting up. It is frustrating that Yarbo keeps wanting to back into sidewalks and gets stuck.
took out the battery out of the rover last night and put it back this morning. Ran plans as test; returned the dock; now charged up to 100% and shows “Battery care active” as supposed. Conclusion; FW updates somehow messed up the battery - reset the battery solves the issue. Thanks, all!
Glad that worked for you!
My front camera stopped working.
You are correct. Sidewalks have a flaw. They are unusable and unreliable. All my S1 breakdowns have come at the fault of a sidewalk. Beware.
I just received the firmware update last night, and did my first run with the new firmware this morning.
I watched Yarbo finish one area, then turn around and DRIVE BACKWARDS to the next area. Then it turned around again and started clearing the area. Never saw that before!!
I’m going to do another run this afternoon and will record it.
Wow, that’s new.
Long story short it’s consistently inconsistent​:sweat_smile:
Mine’s making donuts a lot…I did change 1 of these paths but the routing is…interesting…
Yours is just tired of working in the snow and is playing in it now.
I’ve also been getting Weird routes
